shift boot bracket?
where can I pick one up for my car? The plastic square bracket that holds the shift boot in place, busted it when I did my clutch install. I think the dealership wanted too much for it...
It seems like a that part would be a dealer only part unless you can find one at a scrap yard but that is pretty doubtful. I would just post in the part wanted sections of some of the f body sites and if you can't get one there then dealer.
Mine busted but I just superglued it back and it works fine hope this helped Josh |
I ran into the same thing. I got some "Plastic Welder" JB-Weld sort of stuff... it works just as well. Heck, it set up wrong the other day, and in trying to break the glue, I broke the bracket instead.
Fred |
i went to the dealer last week, and they said it was 119 dollars, i think they had the wrong part, but they couldnt find the right one...so good luck, if you find out where to get one, let us all know!
When I checked on 'em, you couldn't get just the bracket; you had to get the leather part too. That's what made it so expensive.
Fred |
Originally posted by 1995greenTA 119 dollars |
best price I found was $85, using my 'connections' @ the local dealership. Otherwise, any junkyard I found wouldn't sell it separate from a console.
Fred edit: maybe it was $35... I don't recall exactly. Either way, it was too much, and I bought glue:) |
part # 10271369
GM- its a dealer only item.... shift boot with plastic clip.... I just bought one for my 97, was $42 after tax at my local dealer |
Originally posted by Hyperspeed97z28 part # 10271369 GM- its a dealer only item.... shift boot with plastic clip.... I just bought one for my 97, was $42 after tax at my local dealer http://web.camaross.com/forums/showt...ght=shift+boot http://web.camaross.com/forums/showt...ght=shift+boot |
