SES light question...
Old Feb 17, 2009 | 05:23 PM
jtarp's Avatar
Should the SES bulb light up and then go off like the rest of the lights in the gauge cluster when you start your car? If it is, mine never has, and how do I go about fixing it?
Old Feb 17, 2009 | 06:50 PM
Yes, it should come on for the bulb test. You may need to remove the cluster to check for a burned out bulb.
Old Feb 17, 2009 | 07:17 PM
Green96Z's Avatar
I'm not sure about OBD1, but OBD2 will set a MIL circuit DTC if the bulb goes out, which you can check with a scanner.
Old Feb 17, 2009 | 07:44 PM
jtarp's Avatar
Thanks what I was thinking shoebox. Thanks for the help guys.
Old Feb 17, 2009 | 09:58 PM
Both OBD-I and OBD-II have codes for a faulty SES light circuit.
Old Feb 17, 2009 | 10:49 PM
jtarp's Avatar
Ok, how can I scan it for codes. I know the parts stores around here only scan OBD2, or so I believe. What can I use to scan it for codes?
Old Feb 17, 2009 | 11:15 PM
You need an OBD-I scanner, like the Auto X-ray. Then, because your 95 has a 16-pin OBD-II style ALDL connector, you need an adapter plug to go from 12-pin OBD-I to the 16-pin, or you need to use jumper wires as shown on Shoebox's site:
http://shbox.com/1/xraycable.jpg
You can find used Auto X-rays on eBay for low $$$$.
Or, you can use scan software, like FreeScan (free download), TTS DataMaster (free download, 20 free uses), or EFILive V4 (have to pay for it), then get the correct cable to allow you to hook up your laptop to the ALDL connector, from AKM Electronics.
http://www.andywhittaker.com/
http://www.ttspowersystems.com/
http://www.efilive.com/download.aspx
http://www.akmcables.com/
Old Feb 17, 2009 | 11:23 PM
jtarp's Avatar
Thank you for the help. I guess I will look into buying an Auto X-ray for the time being. Thanks again.
Dzmaro
May 7, 2015 09:33 AM
Gtpguy
Jan 26, 2015 04:50 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
Rich_z28
Sep 13, 2002 03:35 PM
Z28Wilson
Aug 1, 2002 04:27 PM
