Service Engine Soon!!?
Old Sep 2, 2004 | 08:10 PM
SkillZ25's Avatar
Ok, me and Bigginz were talkin to another member who said you can fit a V6 Slp cai onto a Z28. We went to my house and tried it. It worked suprisingly easy and its looking good so we go for a ride. It was working well the car sounded better and all that but right when we get home, I pull in the driveway and BING "service engine soon." We were driving for a while though so im puzzled. Also i didnt reset the computer, could that be it?
Old Sep 2, 2004 | 08:21 PM
99blackSS's Avatar
Re: Service Engine Soon!!?
Did you plug everything back in? Might just be a coincidence that the SES light went on after installing the air intake. You should get it scanned.
Old Sep 2, 2004 | 08:45 PM
Kataklysm's Avatar
Theres probly something not plugged in all the way or theres a hole in the intake causing a leak.
Old Sep 2, 2004 | 09:04 PM
BiGGinZ's Avatar
We also plugged the hose going into the intake.
Old Sep 2, 2004 | 09:44 PM
Dave89IROC's Avatar
Old Sep 2, 2004 | 10:14 PM
BiGGinZ's Avatar
The hose going from the cai to the I think air pump.
Old Sep 3, 2004 | 02:22 AM
SkillZ25's Avatar
Well we restarted the comp. by unhookin the battery for a while and, then we took it out again for about an hour and it never came on!!! Sweet !!! but wait, we get into the driveway again and ..... BINGO its back we sealed up the air pump hose so that might be it maybe?
Old Sep 3, 2004 | 03:33 AM
CCRJon's Avatar
It sounds like the problem is with the destination.
The light comes on every time you pull into the driveway
Sooooo
Park on the street or move to a new place
Problem solved
No, seriously - mine did the same exact thing. I got a SLP CAI made for the V8 however. It turned out to be the gasket on the MAF sensor was ripped a little. There are 30 things that could be wrong.
It will take the PCM a few times to figure out that you have a larger air ratio coming into the throttle body now. Keep resetting the PCM to wipe out the codes and try again. Also, make sure that the filters are way clean or even new when you run it. The MAF may have some **** on it.
CCRJon
Old Sep 3, 2004 | 06:45 AM
moparman's Avatar
You can guess and guess what it might be, or when the SES is on, take it to Autozone and have them pull the code.
Old Sep 3, 2004 | 04:39 PM
SkillZ25's Avatar
.....alright i guess I have to 50 bucks down the drain
Old Sep 3, 2004 | 09:34 PM
moparman's Avatar
Autozone pulls the codes for free. Hope you didn't buy something already.
Old Sep 4, 2004 | 02:56 AM
SkillZ25's Avatar
Really cuz one time I tried and they said no...maybe that was Kraigen....Ok ill try autozone today. Thanks for the pointer though.
cheapchevy
Apr 8, 2015 08:48 PM
STR FTR 1
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:36 PM
Injuneer
Dec 15, 2014 09:36 AM
mspennyhughes
Nov 28, 2014 03:22 PM
transamtom
Aug 4, 2002 01:35 AM
