Sensor on the brake pedal assembly......?
Old Aug 21, 2006 | 10:31 AM
Blue96z28's Avatar
I'm doing the t56 swap, and I dont know - what is the sensor which is located above the brake lights/cruise sensor, same style, in all the time(off), and then out to activate, but I don't know what it controls or if I need to reinstall it on the m6 pedals, the guide does not mention it at all, it has a small plug with 2 wires.....is it maybe the sensor for the auto shifter to allow you to shift from park once the brake pedal is depressed????
Old Aug 21, 2006 | 08:52 PM
davidarel's Avatar
Re: Sensor on the brake pedal assembly......?
The brake switch should have the battery power going in and then a lightblue coming out to the brake lights. This switch should also be the cruise release switch. the other switch should be for the shifter lock. I am not positive about the colors since I am not looking at a scematic.
Old Aug 22, 2006 | 01:52 PM
Blue96z28's Avatar
ok, sounds about right, guess theres no need to even have the shifter lock out switch on the pedal assembly now then, thnx
CGM2010CAMARO
Apr 7, 2015 07:44 PM
jj_burchiel
Mar 21, 2015 12:51 AM
eazyZ
Mar 1, 2015 07:12 AM
Red97LT1
9
Dec 17, 2014 06:13 PM
