Self moving thread 93-96 to 97-02 tail lights conversion HELP?!
Old Aug 1, 2010 | 02:37 PM
charliediss's Avatar
Nobody in the original location seemed to want to comment, so I decided to post here, where I know there is a wealth of knowledge on these cars, and there is more than one hit every 4 hours.
Ok, I have found a TON of info for people doing this swap backwards, but none for people trying to switch TO the 97+ style lights. Does anybody have a conversion written up? If so, it would help a ton.
UPDATE:
The problem I am having is that my turn signals share the same hot as the brake lights/running lights. This is due to the 93-96 style using the same location for the turn/runners. SO, when my brake lights go on, so do my ambers. I am running out of extra wire here lol.
Old Aug 1, 2010 | 02:50 PM
For future discussion.
http://www.bfranker.badz28.com/fbody/97lights.htm
Old Jan 27, 2020 | 07:55 AM
flyinZ's Avatar
Re: Self moving thread 93-96 to 97-02 tail lights conversion HELP?!
Does anybody have any pictures, for this write up? I am in the middle of doing this swap, and Id like to confirm WHICH lt-blue wire on the brake switch, needs cut and spliced.
Old Jan 27, 2020 | 09:19 AM
What year is your car?
Shoebox's 95 diagram shows there is only one light blue wire on the “Brake Switch Assembly”, unless there is a similar wire on the TCC switch. Note pin designations.
1995 4th Gen F-Body Exterior Lights
Other years might be different. I have the factory manual for all years.
Old Jan 27, 2020 | 09:26 AM
flyinZ's Avatar
1994
Thank you Fred!
mattoney01
Nov 20, 2009 08:45 PM
JooneJune
Jun 25, 2008 08:05 PM
Z28LT1_Just_Nasty
Feb 15, 2006 12:31 PM
blackrat
Feb 17, 2005 09:10 PM
firepheasent
Mar 22, 2004 10:48 AM
