Security light??
Old Jan 14, 2008 | 06:40 PM
LALT1's Avatar
Security light??
ok, my car will not start. The security light came on a couple of days ago while driving to work then went off. started fine the next 5 or 6 times I started it. now it will not hit, cranks, p[plenty of fuel, just won't fire. it will try to fire 1 time after it sits over night. The security light is on while trying to crank, and as bad as I hate to admit it, I have never paid attention to if it is always on when you crank these over, or if it is signifying a problem.
Thanks for any help.
Old Jan 14, 2008 | 07:58 PM
JAB's Avatar
JAB
Sounds like a VATS issue. Start by reading shoebox's site on it:
http://shbox.com/1/pass_key.html
http://shbox.com/1/4th_gen_tech2.html#pass_key
http://shbox.com/1/vats_bypass.jpg
That should point you in the right direction.
Old Jan 14, 2008 | 08:28 PM
LALT1's Avatar
Also the VATS was programmed out of the PCM if that matters. Which is odd I would think I would even see a security light.
Old Jan 18, 2008 | 03:05 PM
blackbirdta's Avatar
if its a VATS issue wouldn't the car not turn over at all? my car has not started a couple times and the security light was on, but the car would not do anything (as if I wern't pushing in the clutch). i can't find my second ignition key either, but it has only not started a couple times.
Old Jan 18, 2008 | 03:16 PM
JAB's Avatar
JAB
Yeah, I misread it. VATS would not let it crank over at all....hmmm...
You said there is fuel so I would check for spark next.
moparman
Mar 5, 2015 08:47 AM
Oncomingstorm22
Jan 22, 2015 07:15 PM
fpete1992
Dec 11, 2014 03:51 PM
blac94Z
Dec 2, 2014 12:09 PM
JasonD
Jul 15, 2002 02:17 PM
