scanmaster install on 94z
Old Jul 20, 2005 | 01:08 PM
chr10spoke's Avatar
on my 94 will I have to add extra wire. I think I have to go to the ignition slot in the fuse box. And the 12th hole in the aldl is that correct.. I have 22-18 wire little slot things that will fit in fuse box but not in the computer slot. I was told to file down the one for the pc slot a little smaller and it will work.
The plastic piece under the steering wheel. If I take that off is there a good ground under there.. thanks for any help.. Also I believe I am going to have slit that gray plastic around the wires to seperate all 3 wires..
Old Jul 20, 2005 | 01:14 PM
Re: scanmaster install on 94z
Read the install part of my online ScanMaster writeup. Connect the white signal wire to the bottom right pin on the ALDL (tan wire), the red wire to any +12V source and the black wire to any good chassis ground. Finished.
I spliced the white wire into the tan wire on the back of the ALDL, rather than use a pin. And then added a micro switch, mounted above the ALDL connector so the ScanMaster could be disconnected when any other device had to be connected to the ALDL.
http://members.aol.com/InjuneerZZ/ScanMast.htm
Old Jul 20, 2005 | 03:22 PM
chr10spoke's Avatar
thanks injuneer,
radio shack has this micro switch I presume...
Nov 18, 2023 07:21 PM
Peytons'z
May 6, 2021 09:25 AM
thenewkid
Nov 29, 2014 04:54 PM
Ken95Z28
Aug 21, 2002 04:32 PM
