SBC into LT1 body
Old Jun 21, 2008 | 08:10 PM
ZONES89RS's Avatar
SBC into LT1 body
I need to know if i can use the HEI, it looks like it will fit after trimming the cowl.
Also, can i make the stock serp system work with it and make the WP work with different size belt and routing? If not, can a third gen system work and make the AC still usable?
Old Jun 22, 2008 | 04:08 PM
ZONES89RS's Avatar
OK, i found the HEI will fit. Now, a friend told me about a pulley that will go on the aternator for a separate belt to go to the water pump, anyone heard of this?
Old Jun 23, 2008 | 09:25 AM
Rice Killer87's Avatar
Sounds like your talking about a V-belt system, which uses 2 or 3 different belts instead of a serpentine using just one.
Either will work, depending on funds you could buy one of those March serpentine setups.
Old Jun 23, 2008 | 03:00 PM
ZONES89RS's Avatar
I want to use the stock serpentine system. I think my answer is to use a electric water pump, problem solved prolly.
redleader
Parts Wanted
Nov 13, 2016 02:57 PM
Jason Short
Jan 19, 2015 06:34 PM
lt1-xjs
Jan 17, 2015 07:52 PM
InfernalVortex
Jan 17, 2015 09:35 AM
