Rough idle...low on power
Old 08-17-2012, 09:51 PM
DomsZ28's Avatar
Hi everyone. My 95 Z28 Camaro has a problem. At idle the car acts like it wants to die almost where all the interior lights and headlights flicker on and off. but as soon as i hot the accelerator its fine. On the highway the car just doesn't feel "right". I can feel the car vibrating and shaking at idle and at highway speeds. feels a bit low on power too. It does it immediately when I start it...hot or cold. Here's the kicker, in the last month I've replaced...Fuel pressure regulator, fuel filter, plugs, wires, AND the Opti(Although it was replaced with a junky re manufactured one from Autozone.....Long story...) Thanks for any input in advance.
DomsZ28 is offline
Old 08-17-2012, 11:44 PM
mrmint69's Avatar
Re: Rough idle...low on power
Any check engine lights?
mrmint69 is offline
Old 08-17-2012, 11:47 PM
DomsZ28's Avatar
briefly it illuminated but after i turned it on/off it went away. I wouldnt even know where to start by checking it anyway since its a 95..It'd be a pain
DomsZ28 is offline
Old 08-18-2012, 08:32 AM
mrmint69's Avatar
You can't keep guessing at whats wrong. For the price you paid for parts that were not bad, you could own a code reader. Your previous thread explains how to retrieve the codes. I personally think using a cable with your laptop is the cheapest and by far the best option there is.
mrmint69 is offline
Old 08-18-2012, 10:07 AM
DomsZ28's Avatar
Where can I purchase a cable for my laptop? How does that work?
DomsZ28 is offline
Old 08-18-2012, 10:19 AM
bobdec's Avatar
Search on 'OBD1 USB ALDL Cable' I got mine here ALDL OBD1 OBD cable OBDI OBD2 engine codes . Some good reading and links at this site. NOTE your car is OBD1 but since it is a '95 it uses the 16 pin (OBD2) style dash connector cable. Next you can download FreeScan from here FreeScan . Set up com port in Freescan and click Force Data interact and start communications. Or to see DTC display, there is a selection on the main screen. You can get lots of help here if you have any problems. If windows 7 or Vista I think it may need to install and run in compatibility mode, not sure, search around if needed. .
bobdec is offline
Old 08-18-2012, 09:15 PM
DomsZ28's Avatar
Thanks Bob, I will definately be looking into that. But the light hasn't been on for a few days now so I am back to my original problem. Any one have ideas?
DomsZ28 is offline
Old 08-18-2012, 11:55 PM
mrmint69's Avatar
You don't need the light to be on to have a stored code. Plus some codes do not even turn the light on. Have you checked to see if any parts stores have the right code reader?
mrmint69 is offline
alex5366
05-07-2015 10:28 PM
Noenav
04-30-2015 01:06 PM
alex5366
04-01-2015 09:27 AM
Bignasty85
03-03-2015 04:05 PM
XtremeLt1
09-13-2002 08:50 PM
Quick Reply: Rough idle...low on power
