Right signal does'nt work
My right side turn signal does not work. The bulb is fine in the back but have not checked the front. The weird thing is when I turn the signal on the light on the gauges just stays on and does not tick. And the front and rear right singal neither of them work while the left one inside and out are fine. Anybody know what the problem is. Thanks for any help
Re: Right signal does'nt work
Probably the front bulb is burned out but it could be a bad flasher it's normal when a bulb is out for the light to come on and stay on without blinking. I would start by checking the front bulb and if it's good then you prob need a flasher.
