Replacment headlight motor 93-97
Old Sep 21, 2008 | 11:07 AM
Warren_Seale's Avatar
Well my headlight motor went out again. This will be about the 4th one since I've had the car (original owner). I've tried replacing the plastic gear with a metal one but was never successful due to the housing always popping open. The epoxy was never able to hold it together for any length of time. I tried like 4 or 5 times but it wouldn't hold.
The good news is that Cardone is now rebuilding them and it includes a lifetime warranty. So I'll never have to pay for another one again. My local Advance Auto Parts carrys them.
So if anyone has this problem here is another option.
Warren
Old Sep 21, 2008 | 02:06 PM
moparman's Avatar
O'Reilly's also has them. Might check pricing.
Old Sep 22, 2008 | 10:49 AM
slomarao's Avatar
az, 28.99
Old Sep 24, 2008 | 07:06 PM
So it turns out the reman motors have a different case, one that can be taken apart and reassembled by using 3 screws. No more epoxy required!
Warren
Old Oct 2, 2008 | 02:32 PM
97WS6's Avatar
You may want to try a quick fix before buying another motor. It takes about a half hour. I just did it on my 97WS6 and now have a working and quiet headlamp.
Go to this site and check it out:
http://www.bfranker.badz28.com/headlightfix/#FreeGuide
This fix is done without the motor being disassembed and is worth the half hour it takes to see if it works for you. FYI, if you do this be sure to use some tape to hold the headlamp open after pulling the up/down lever off of the motor shaft or it falls shut.
After I did this the lamp opens and closes like new with no noise.
By the way, this was my first headlamp motor failure since I bought the car new in 1997.
Good Luck.
Old Oct 2, 2008 | 02:38 PM
Good Luck.
Well I already used up my 1 free fix. I used it a few years ago.
Warren
transam_388
Mar 15, 2015 11:53 AM
Injuneer
Advanced Tech
Jan 15, 2015 02:49 PM
CaRParts102
Dec 6, 2014 08:45 AM
97 RedSS
Jun 10, 2003 07:58 PM
