Replacing Brake Rotors
Old Oct 22, 2004 | 10:04 PM
Spllouder's Avatar
ok both front brake pads need to be replaced . And it looks like one rotor is ok and one is bad. the bad one i will replace. But this is my question is it not good to replace just one side on the front . will i get any shaking or virbating beacuse i have differnt rotors on being one new and ones old and a little worn . ?
or should Both be replaced ?
Also will a pad all the way gone cause abs inop light to come off and on The pad is grinding into the rotor made a big grove ?
Thanks ,
Old Oct 22, 2004 | 10:24 PM
TheBiz's Avatar
Re: Replacing Brake Rotors
Go ahead and replace both rotors while you are under there. Trust me, unless you want to change one at a time for the next 15 years...do them both now. The ABS Inop. light shouldn't come on for a pad. It could be anything. Those things are REALLY touchy.
Good luck man, brakes shouldn't take you more than an hour. Its pretty easy on our cars.
BIZ
Old Oct 22, 2004 | 10:33 PM
Spllouder's Avatar
whats the differnce between these two ?
Wearever Silver MKD623 ? $18.88
-and-
Wearever Gold MKD623 ? $29.98
Or are there better pads out there ?
ALso ill will buy these rotors Any good ? Wearever YH141868 $21.88
Any betters one for around same price also this is for my other v6 camaro not my z so i dont need nothing fancey . i save that for my Z
Old Oct 22, 2004 | 10:42 PM
TheBiz's Avatar
Do either of those have a lifetime warranty? IMO, go to autozone, by some of there carbon metallic pads (like $25.00). When they wear out the next time, take them off, and return them for a new set, free of charge! I usually just go to autozone and get their pads and their rotors. If you don't want anything fancy, just hit them up. Easy, and pretty cheap.
BIZ
Old Oct 22, 2004 | 10:54 PM
kmdracer's Avatar
I can def vouch for the autozone rotors (amico's if I remember correctly) I had problems on my 99Z with the front rotors warping @5000 miles or so. After the 4ht set of factory POS ones, I bought the amicos. 40,000 miles later, they're doing fine!
Old Oct 22, 2004 | 10:58 PM
Spllouder's Avatar
yep both those are semi maltallic pads with limted life time warrenty
but rotors only 1 years
Also how much brake fluid will i need to change and bleed the brakes , I wanna change the brake fluid too . Also how do u bleed brakes properly?
thanks biz for ur input .
Old Oct 23, 2004 | 12:41 AM
D James's Avatar
hey guys what about rear rotors, i see they're pretty expensive, arund 70 bucks each. Mine are uneven , they look smoth but when I touch them I can fel they are kinda ruff, should I just get them turned, or buy new ones, are the autozone ones just as good, I don't want to spend al osrts of money to have them go bad.
Old Oct 23, 2004 | 01:10 AM
Spllouder's Avatar
these are good
rear disc rotors for z28
Wearever YH141888 $35.88 Each
also,
Raybestos 1056407 $29.99 Each
Old Oct 23, 2004 | 01:43 AM
Z95m6's Avatar
If i was you i wouldn't dump any money into the crappy LT1 brake setup especially when the LS1 set up is so cheap. Here you can get some with rotors turned all you would need is the pads. You can get pretty much a complete setup for $150 and its 10x better than the LT1 setup. The LS1 set up has bigger rotors, dual piston calipers and i believe more pad surface area.
http://cgi.ebay.com/ebaymotors/ws/eB...category=33564
I got my LS1 set from this seller they are an Fbody salvage yard. http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWA%3AIT
I didn't win my set but i emailed them and offered to buy a set for the price on this auction. I got them shipped to my door for 165. I reused the pad and rotors and it was still better than my LT1 stuff. I ended up buying CAMARO decals, paint, brake cleaner, brake fluid, and other small parts and installing this setup for less than $200 all together. I love it.
Old Oct 23, 2004 | 10:09 AM
TheBiz's Avatar
I didn't bleed my breaks at all when I changed mine. If you do bleed the breaks, you only loose a timy amount. Its nothing to be concerned about. You may want to top of the resevoir after, but it is a super tiny amount. Just buy a bottle, and you can have it setting around.
Oh yeah, you may already know this, but I would feel better if I said it anyway. Make sure you clean the rotors before you put them on. They come with a coating that prevents flash rust. Take some Break Clean, or some rubbing alcohol, and rub them down. If you don't your pads will gum up and you wull be doing it ALL over again really soon.
Good luck man,
BIZ
Old Oct 23, 2004 | 01:39 PM
Spllouder's Avatar
ok bought 2 new rotors and some new pads Cost was $66
and again this is for my other camaro the a v6 if i do brakes on my 94 z28 i would go ls1 but there good for now .
going put them on soon thx for all the info ill let u all know how it comes out .
1 quick question ppl say u need to open the blearer screw when u depress the piston back in when u put the new pads on . Do i have to do this ?
Also where are the bleader screws what size socket ????
thanks ...
Old Oct 23, 2004 | 01:54 PM
TheBiz's Avatar
Don't worry about the bleeder screws. Just take the cap off the resevoir and squeeze them in slowly. It might be a good idea to rap a rag around the opening. You may lose a little, but its much easier than messing with the bleeders. Then just top off what little came out. Usually you will only get a few onzes of overflow. Its a pretty strait forward job.
Good luck man.
carguy0119
Apr 11, 2016 11:11 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
dale3in98
Feb 14, 2015 12:18 PM
Jazsun
Dec 29, 2014 12:14 PM
