replaced fuel pump..now it hesitates..help!
Old Aug 10, 2004 | 04:12 PM
97firebird's Avatar
Hey guys, I thought I would try and solve my starting problem (won't start until I crank it about 5 times and then let off and start it again) so I replaced my fuel pump with a used holley pump. The thing was screaming when I plugged it in to test it so I know it works. Here is my problem now...I went to drive it down the street and when I press the gas hard the car sputters and hesitates...which I am guessing means that it is not getting adequate fuel. I did have trouble making the plastic cover over the fuel pump stay seated and glued, and the pump that I bought did not use any rubber gasket or anything at the bottom where it drops into the stock plastic case. The top gasket I used from the stock pump and it seemed to seat well, but I dont know how well. Also, it seems like there is a lot of hussshhhing going through the gas lines where i cut out the trap door...almost sounds like the gas is mixed with air. So I guess my question is...what the hell did i do wrong? or could the problem be elsewhere now that I have a high-flow pump? I am going to be screwed if I can't fix this problem myself because I hate bringing it to a shop to fix what I already tried myself.. Any help would be appreciated!! Oh, by the way...it didn't fix the starting problem..Now I am thinking fuel pressure regulator?? ANybody?
Old Aug 11, 2004 | 11:23 AM
Ace_437's Avatar
Re: replaced fuel pump..now it hesitates..help!
Why did you put a used fuel pump in? It's a PITA to change so you should have just ordered a new one. Maybe the pump is going bad. Did you change the filter too?
Old Aug 11, 2004 | 11:31 AM
Ucantcme57's Avatar
Wonder why people sell good race parts for cheap?
Go out of the tank pump...
Old Aug 11, 2004 | 12:49 PM
Hyperspeed97z28's Avatar
dirty fuel filter maybe ?
Old Aug 11, 2004 | 12:54 PM
HBHRacing's Avatar
agreed, why risk a used electrical part? also. when you say you "tested it" you let it run out of the tank without pumping gas through it? thats another bad idea.
a fuel pressure test would be helpfull. but other thoughts that come to mind is a comtaminated MAF mimicing a low fuel volume condition
Old Aug 11, 2004 | 02:47 PM
97firebird's Avatar
Wow, I love it when I need help and all I get is criticism...Thanks alot guys. Sorry, I'm not a millionaire and Im not a mechanic, just trying to fix my problems on my own. I didn't ask to be bitched at.
Old Aug 11, 2004 | 03:11 PM
HBHRacing's Avatar
we are giving you sugetions.. filter, MAF, etc etc. if you wnana make sure that the pump is ok do a pressure test. if you emiminate that your fine. we are just trying to help educate on what could be helpfull. Used electronic parts are generaly a bad idea. Like someone I helped with a LT1 no spark. it was teh opti. he bought a used one.. then got mad when it didn;t work. blamed me. re ran the test and the opti was bad. orderd a kit from autozone. I told him it would not work. did it anyway and blamed me again. fianly bought a brand new delco unit and it fired right up. we say these things for a reason. cause we have been there. I have several used parts on my car. but some are just not worth the time of installing.
Old Aug 11, 2004 | 03:20 PM
Ace_437's Avatar
Nobody was bitching at you, just questioning your decision.
kaoticcamaross
Feb 17, 2015 03:13 PM
Scottyboy
Feb 11, 2015 10:28 PM
Alex Barnes
Jan 24, 2015 10:21 PM
ANDYZ28
Dec 29, 2014 09:13 PM
