repeat bulb burnout
Old Jan 17, 2006 | 02:50 PM
kkollwitz's Avatar
repeat bulb burnout
The original front turn signal bulb burned out on my 2002 Camaro. I replaced it, 2 days later it's apparently burned out again. What's up?
Old Jan 17, 2006 | 06:07 PM
Kataklysm's Avatar
Re: repeat bulb burnout
It's being shorted or burnt out by to much voltage. Take the bulb out and check the voltage with a digital multi meter.
Old Jan 17, 2006 | 06:44 PM
Dave89IROC's Avatar
well, he can't have more voltage at the bulb then battery/charging system voltage, so, as long as hes charging ok, thats not it,
Old Jan 17, 2006 | 08:06 PM
Kataklysm's Avatar
Maybe his voltage regulator is junk and for some reason that bulb is whats taking the hit?
Old Jan 18, 2006 | 07:17 AM
kkollwitz's Avatar
what a moron, I hadn't put the bulb in tight enough & it came out.....
94_Z28_guy's Avatar
As another possibility (if you haven't already) try using dielectric grease on the bulb, and alot of it. I had a similar problem with a brake light, and I haven't had to replace it in several years. Just an additional thought.
Old Jan 18, 2006 | 07:38 AM
Dave89IROC's Avatar
LOL, opps...........
Aug 24, 2015 11:04 PM
Bxlt1
Jul 18, 2015 02:48 PM
Boss002
Jul 9, 2015 03:33 PM
