Removing underhood insulation?
Old Jul 11, 2008 | 10:12 AM
Jazsun's Avatar
My insulation has a burn/mouse ate part of it...Looks like ***. At the track Ive seen most other Fbodys have already removed the insulation. Is there any downside to removing it? Such as does it help in the winter? Will removing it help lower temps under the hoods? Will it damage the hood paint?
Old Jul 11, 2008 | 12:26 PM
Bluovlh8er's Avatar
i removed mine... just ripped it down, got a qt of flat black paint and brushed it on (no over spray) looks great.
Old Jul 11, 2008 | 12:41 PM
EnFuegoZ28's Avatar
So no dowside to removing it?
Old Jul 11, 2008 | 02:39 PM
Lunch Box's Avatar
No downside that I'm aware of, I think it's just there to help with the noise from under the hood - my '02 Z28 didn't have any from the factory
Old Jul 11, 2008 | 04:34 PM
Nuke's Avatar
Had mine off since 1997. No problems.
Old Jul 11, 2008 | 04:58 PM
The SS and WS6 hoods do not have insulation. Does not seem to affect the paint. The fiberglass construction of those hoods will reduce heat transfer through the hood, compared to the standard steel hoods, but the inside surface of my SLP/WS6 hood is painted w/ clearcoat, same as the top of the hood, and its still just as shiney 8 years after it was painted.
I doubt that removing the insulation will affect the under hood temps too much. There's just way too much heat coming off the exhaust system, and out of the back of the radiator. I found that there was a nice reduction from removing the big rubber gasket that seals the hood to the cowl, but that lets a lot of water in, a lot of it falling directly on the PCM.
Old Jul 11, 2008 | 06:55 PM
MarcR94v6's Avatar
the insulation is for noise and water only, not heat in any way.
Old Jul 12, 2008 | 09:24 AM
MARKTHOMASBRAND's Avatar
Ripped my insulation off about a year ago.No problems with paint etc.Car still runs at the same temperature as before.
Regards,Mark.
Old Jul 12, 2008 | 11:35 AM
fxgs's Avatar
Originally Posted by Injuneer
I I found that there was a nice reduction from removing the big rubber gasket that seals the hood to the cowl, but that lets a lot of water in, a lot of it falling directly on the PCM.
I agree.............did the same on my Corvette..............it does make a difference....................and I have a cover over the PCM that prevents water from dripping on it.
greenzee28
Sep 25, 2015 04:29 PM
wbspoon
Sep 19, 2015 08:12 AM
marlar98
Sep 19, 2015 07:53 AM
NewsBot
Sep 14, 2015 09:20 AM
RX Speed Works
Sep 11, 2015 03:31 PM
