removing Interior any advice?
Ive had water in my car have to track the problem... is there anything I should know about removing the interior and what is all involved? Are the seats easy to take out? I also have to remove the plastic siding inside the car... looks like the leak is running down inside the walls of the car (behind the plastic)
isn't really that hard. i pulled all of mine out when it flooded in the hurricane
plastic is mostly just screws and some small bolts.
the bigger bolts should be either 13 or 15mm
the torx bolts for the seatblets will be 47 i think...but a 50 will work in a pinch
you'll have to pull the whole center console out to get the rug. but that's easy once the seats are out.
Found the leak, its coming in between the t-top and drivers window. I got broken into a year ago and the guide wheel snapped. It never got fixed so the window alignment more than likely has something to do with it. The seatbelt is wet near the top all the time when it rains.
grabbem88
Feb 10, 2015 06:20 PM
squarehead
Nov 21, 2014 08:02 PM
JasonD
Jul 27, 2002 08:57 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
