Remote keyless entry...
Old Sep 8, 2004 | 03:09 PM
brickhoss's Avatar
Hey guys, quick question... Just got my 1996 Z28 and the remote entry doesn't work at all most of the time... but occassionally the lock does... but for the most part nothing... So I have to use the key to get in... and i have to start the car in like 4 seconds or the panic goes off... Any suggestions? I have fresh batteries in both of my remotes... but still nothing!!! Thanks
Old Sep 8, 2004 | 03:57 PM
unvc92camarors's Avatar
Re: Remote keyless entry...
probably the contacts
you can take it apart and clean them every so often or just get new remotes
you can find new remotes on ebay pretty cheap
Old Sep 8, 2004 | 04:01 PM
MustangEater82's Avatar
How hard are they to take apart and what size batts do they take?
And to take it apart, jsut pry them with a flathead screwdriver?
My girlfriends is acting up on her 2k Cavalier looks identical to mine. I was jsut about to post something.
Old Sep 8, 2004 | 05:01 PM
i've never done it but it seems like the only way to do it is like you said, pry with a flatheaded screwdriver
the contacts will probably just need to be wiped off or something and i'm not sure but...the battery number might be on the battery itself
Old Sep 8, 2004 | 09:15 PM
KPZ-28's Avatar
My remote did the same thing, I would have to hold the buttons in for 5 seconds before it would lock or unlock. After taking it apart I discovered it had condensation inside which I dried with a soft cloth and sprayed the contacts with CRC contact cleaner. I replaced the battery with a 2032 battery and now it works great!
Old Sep 8, 2004 | 10:28 PM
fought70's Avatar
well i just replaced my batteries. the manual said 2016 for the size. so that's what i got. your best bet would be to use rubbing alcohol. get all the corrosion and moisture and stuff off.
Old Sep 9, 2004 | 09:07 AM
which manual? the owner's manual?
i was about to suggest that but figured they wouldn't have a part # like that in it
Old Sep 13, 2004 | 10:48 AM
brickhoss's Avatar
Hey guys... I've been away since I posted this... But I came back today and cleaned the contacts as suggested, and it works great!! Thanks for the help!
Old Sep 13, 2004 | 11:02 AM
wwarnke's Avatar
I am having similar problems, also, shoud my horn honk when doors lock?
Old Sep 13, 2004 | 06:05 PM
red96taA4's Avatar
the horn doesnt have to honk, you set it how you want it. look in your owners manual, and if you dont have one, goto shoebox's website, he has one in pdf format to download.
chris
Old Sep 13, 2004 | 07:25 PM
blackbirdta's Avatar
mine wasnt working very well so i opened it and cleaned the contacts with a pencil eraser and it worked fine...now its not working again. its time to just buy another...not a big deal
Old Sep 28, 2004 | 09:29 PM
Fast Caddie's Avatar
My keyless does the same thing. Works sometimes but not others. Turns out it isn't the remote... i cleaned the terminals and put in a new battery and all. The problem is actually the harness that goes into the keyless entry module has a bad connection somewhere. The box is behind the passenger side kick panel. Sometimes it'll act up and i can pull the module out and wiggle the harness a little bit and it'll work fine. Either that or beat the crap out of the panel so it wiggles the module enough to make it work. My problem is that the harness is in there as tight as it'll go... i guess it's just one or more of the wires in it have come loose. One of these days i'm going to pull it and reset all the wires in the harness a little deeper so they'll make better contact.
If all else fails pull the module out and work with the wires to make sure all are making good connection.
Old Sep 28, 2004 | 11:50 PM
TraceZ's Avatar
chris
You cannot set the horn to honk in 94 cars.. that didnt work until 1997.
Aaront810
Aug 29, 2020 09:34 PM
Quickss96
Jan 29, 2016 05:56 PM
IndyZman
Oct 22, 2015 02:17 PM
football4life
Oct 4, 2015 07:48 AM
WPHIG2
Aug 27, 2015 06:37 AM
