Regular or high-temp anti-sieze for spark plugs?
Old Feb 28, 2007 | 09:37 AM
wrd1972's Avatar
I have used copper high temp in the past and I noticed that once the plugs were cracked loose it was still to tight to turn with your finger temps. I am wondering if i am using the wrong stuff. I figure they should spin freely.
What is the best anti-sieze for aluminum heads that will allow the plug to be easily removed? Am I using too much?
Old Feb 28, 2007 | 10:47 AM
The Permatex anti-seize that I use doesn't say high temp on it. That's all I have ever used. You don't need to go crazy with it. A little goes a long way. Never a problem with any plugs.
Old Feb 28, 2007 | 11:12 AM
2000GTP's Avatar
I just use the standard nickel anti-seize and a very small amount at that. Plug removal has never been a problem and I have never had a plug become loose.
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
markzzzz
May 8, 2015 09:21 AM
blkWidow
May 3, 2015 08:42 AM
nikko
Apr 20, 2015 07:56 AM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
