rear view mirror light stays on
Old Aug 29, 2008 | 10:54 AM
vin1382's Avatar
Hello,
In my 96 trans am, my rear view mirror lights are staying on. when I close the door, normally the light stays on for a minute and then fades out. now its staying on unless i unplug the battery. The lights are definatly in the off position. I guess something is stuck somewhere.
any ideas?
Thanks.
Old Aug 29, 2008 | 02:00 PM
moparman's Avatar
Try opening and closing the hatch.
Old Aug 29, 2008 | 05:37 PM
The interior lights are turned on by the door switches and the hatch switch shorting to ground. It isn't unusual for the door switches to corrode and short. Pull each of the door switches out, so they can't ground to the chassis, and see if the problem goes away.
Old Aug 31, 2008 | 10:44 AM
vin1382's Avatar
ok thanks guys i am going to try that today and see how it goes!
Old Aug 31, 2008 | 06:23 PM
vin1382's Avatar
ok tried that and the lights are still on unless i pull the courtesy fuse. Any more ideas?
Old Aug 31, 2008 | 06:24 PM
moparman's Avatar
Did you open and securely close the hatch?
Old Aug 31, 2008 | 07:07 PM
vin1382's Avatar
yes. light still stayed on.
Old Sep 1, 2008 | 09:49 AM
Then you have a short in one of the wires that connects to the door switches or the hatch switch. I had that happen when a shop put a couple bolts through the hatch well liner, into the rear sheet metal, bolted down a nitrous bottle clamp, and crushed one of the wires to the hatch switch or the overhead light (can't remember which it was).
Old Sep 1, 2008 | 04:48 PM
1997whitez28's Avatar
same problem
slap the dash board or hold down the power windows and then slap the dashboard on the side of the heater and cd player is and on top.
It goes away but comes back in 20 min.
Take the bulbs out, thats what I did.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
STR FTR 1
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:36 PM
Fatdog2
Jan 24, 2015 12:08 AM
Red97LT1
Jul 28, 2002 06:37 PM
