Ramps for lowered cars
Since I've lowered my 94 convertible, my old ramps do not work. I also have an RS front air dam which makes it even harder to get the car up on the ramps. Any brand better than others? What is everybody using?
I've heard that Rhino ramps work well for lowered cars
. But yeah, if you use a couple 2x4's (or 2x6's) ...
Edit: I suddenly got reminded of this thread
. In particular, from about post #15 on!!
I could not get the car on ramps. A "97" with bilstein Level-2 SLP shock and spring pkg (1" drop). I jack the Rt side up, then use a floor jack under the front engine cradle (set the brake). Then, go for the rear under the axle diff with a floor jack just in front of the rear wheel. A pain in the Azz.
I've been using the 2x4 trick for as long as I've had my cars. 2x6's would work better with your 275's though...I know I always had to lay a pair of 2x4's next to eachother because of the width of the tires. You may even have to get two different lengths and make steps for your car, that's what I have to do with my blue car because of the ground effects.
oldschool
Feb 9, 2016 09:21 PM
Dec 1, 2014 08:08 AM
