Radiator woes- NEED HELP PLEASE!
Old Mar 18, 2007 | 03:33 PM
mikes98z's Avatar
Hey all,
I am in the garage swapping in a new radiator. The original one spring a leak. I picked up a new modine from advanced auto and it matches up to a T for one thing. There is a provision at the bottom corner on the drivers side where a small hose (approx. 3/4") goes. The new radiator does not have this provision. What is the purpose to this small hose goin into the radiator? I had to order the radiator so it would take me a few days to get another one and I have to work in the am!!!!
Is there any way to bypass it by using a T?
Its #16 in the diagram
http://shbox.com/1/95-97_hoses.jpg
Thanks in advance!
Mike
Old Mar 18, 2007 | 06:54 PM
OBE1 95Z28's Avatar
On my 95 that hooks up to the oil cooler.
Old Mar 18, 2007 | 09:17 PM
If you don't have an oil cooler, just cap off where that hose goes on the water pump. You don't have to have it.
Old Mar 19, 2007 | 06:55 AM
mikes98z's Avatar
ok, thanks! Mine is a 97 T/A and the hose went to the bottom of the radiator. I do not have an oil cooler. I just bypassed it for now with a T fitting but I need to find something to cap it with that won't leak and can take the heat. Any suggestions?
Thanks!
Mike
Old Mar 19, 2007 | 09:24 AM
OBE1 95Z28's Avatar
My local auto parts store sells a black rubber cap that's 3/4" ID, hose clamp it in place.
Old Mar 19, 2007 | 10:03 AM
Thanks!
Mike
Pull out the pipe, tap the hole and install a pipe plug.
Old Mar 19, 2007 | 10:04 AM
mikes98z's Avatar
ok, thanks again for the insight. I will stop by today and see if they have one.
Formula Steve
Sep 19, 2023 08:31 AM
93 RedBird
Nov 15, 2015 08:24 AM
IndyZman
Oct 22, 2015 02:17 PM
68camaroboltz
Oct 5, 2015 01:46 PM
Pwilson59
Sep 3, 2015 08:47 PM
