R.A.P. attack
Old 09-01-2009, 02:09 PM
98ZEMT's Avatar
R.A.P. attack
Why does my R.A.P. not work in my 1998 Camaro Z? I've checked fuses and i can't find anything. ?????????
98ZEMT is offline
Old 09-01-2009, 06:46 PM
Could be a BCM problem.
shoebox is offline
Old 09-02-2009, 12:36 PM
Chevyssoccer's Avatar
could be, or a bad door pin
Chevyssoccer is offline
Old 09-02-2009, 05:07 PM
98ZEMT's Avatar
door pin? bcm? elaborate please!!! I'm new to newer car technology. I'm mostly a Mustang man. This is my first 4th gen. I'm familiar with 3rd gens. How much does a BCM cost? What about the door pin thing? Is this fairly easy to change? I can change clutches, rebuild engines. I just don't do much rewiring. I suck at wiring. Thanks guys.
98ZEMT is offline
Old 09-04-2009, 09:42 AM
does your dome light work correctly? when you open either door individualy, does it turn on? If the car thinks the door is open all the time it tells the RAP not to operate. Sometimes with aftermarket alarms/keyless the easier way that they are wired into the dome light circuit causes the RAP to stay off.
Old 09-05-2009, 05:30 AM
98ZEMT's Avatar
I do have an aftermarket security system. Maybe that's the problem. I want it removed anyway. I have the factory security system in it already. Why would someone put another one in?
98ZEMT is offline
Old 09-09-2009, 10:29 AM
they usualy have longer range and are more sensitive with more options if they are installed correctly and working correctly. If that is the only problem with it, you could just disconect the domelight supervision wire on the alarm
mark0006
09-14-2015 12:35 PM
Quick Reply: R.A.P. attack
