Quick question for people that went over the axle with True Duals
Old May 9, 2006 | 02:31 PM
Gripenfelter's Avatar
For those of you that did 3" (or even 2.5") true duals over the axle, did you relocate that fuel pump relay plug mounted to the driver's side seat hump? I want to run one pipe on the driver side and one on the passenger side. The driver side is the one with the issue.
Its a set of 2 blue and white plugs. One plug comes from the fuel tank and the other goes to the front of the car.
If you did relocate the plugs, how did you remove them? Did you do anything to protect them from heat?
I've already modified the Panhard Bar brace for extra clearance.
Old May 11, 2006 | 01:18 PM
BradcTA's Avatar
Re: Quick question for people that went over the axle with True Duals
I used zip ties. FYI, under the axle will get you a lot more power than over (No bends). I've had both.
Old May 11, 2006 | 01:22 PM
teke184's Avatar
why would mandrel bends create a noticable increase in power??
Old May 11, 2006 | 02:33 PM
BradcTA's Avatar
The exhaust guy bent mine almost 90 degrees to make a u-bend to go over the axle. Cut those off and went with straight pipes under the axle and it had a lot more power.
Old May 11, 2006 | 03:15 PM
wdtiger's Avatar
According to the butt dyno?
Old May 11, 2006 | 03:55 PM
BradcTA's Avatar
Technically, yes; but it was a MAJOR improvement in power and sound.
Old May 11, 2006 | 10:24 PM
teke184's Avatar
sound yes...
power...doubtfull
true duals over a single pipe catback is about 10hp on a decently modded engine....how much of that 10hp do you think you were losing by adding extra bends...2hp??
it was in your head
alphaauto
Jan 22, 2015 08:02 PM
Queens94z28
Nov 20, 2014 06:03 PM
RedLineRev
Jan 23, 2003 03:51 PM
