quick question on aluminum flywheels
Old Nov 18, 2004 | 02:00 PM
Quick96Z's Avatar
i know that there are alot of theories floating around about aluminum flywheels vs steel flywheels regarding which one is better for drag racing and which one is better for autocross. It makes sense that having a steel flywheel is benefit for off the line acceleration at the strip, but with an aluminum fw, wouldn't the benefit of having less roatating mass the rest of the way down the track quickly overcome the negatives of the al. fw. I just want to know if anyone has every actually tested any of this, or if it is just speculation on what people think would happen. Can anyone give me any real world comparisons between aluminum and steel. Does anyone have any gains at the strip or gains at the dyno??
By the way, my clutch is toast and 15,000 miles ago when i did my last clutch job i just simply picked up the LT4 pressure plate and clutch from slp, and i just replaced the fw with a stock piece from work. This time around i want to go with something that may help me pick up some time at the strip.
thanks for any input guys
trav
Old Nov 18, 2004 | 11:46 PM
Red_94Formula's Avatar
Re: quick question on aluminum flywheels
The SLP billet steel flywheel only weighs .5 pounds heavier then the Fandiza(sp?) aluminum flywheel. And it is still 10 pounds lighter then stock plus much cheaper then aluminum.
Old Nov 19, 2004 | 11:26 AM
LPEdave's Avatar
There was a nice test done a couple years ago, I think it was by the Mustang mag, something like MM&FF or whatever they go by, that concluded that a lighter flywheel is better all around for drag racing, road racing, etc. I think it commented on a bit of reduced driveability, but if you're after performance, lightweight is the right answer.
Dave
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Ringmaster72
Feb 25, 2015 03:15 PM
alex5366
Feb 17, 2015 09:07 AM
94Form
Feb 10, 2015 11:23 PM
