question about dash lights
Old 08-13-2005, 10:28 PM
Fly Z28's Avatar
Question question about dash lights
one of the bulbs in the A/C-heater controls on my 95 Formula is out. I got the thing apart, but have no idea as to how to replace the bulb. it is a real tiny bulb and is not coming out of the socket. If anyone has dealt with these before, I appreciate any advice.
Bret
Fly Z28 is offline
Old 08-14-2005, 10:32 AM
Z95m6's Avatar
Re: question about dash lights
The bulb just pulls out. Its like a mini version of the 194 bulbs that are in your cluster and tag light and such. They don't twist or anything they just pull straight out. Usually they break and you have to use plyers or something to pull them out. The small bulb is a #74 bulb, they are also used in door panels to light up your window/lock switch area.
Z95m6 is offline
Old 08-14-2005, 12:37 PM
MarcR94v6's Avatar
What if you put a new bulb in and it still won't work? I checked the fuse and it seems fine. Probably wiring right? But where do I get new wiring?
MarcR94v6 is offline
Old 08-14-2005, 07:07 PM
Z95m6's Avatar
Bust out your test light and see if you are getting juice to the bulb socket.
Z95m6 is offline
Old 08-14-2005, 10:45 PM
Fly Z28's Avatar
thanks, I actually found a parts store with someone that had a F body and he knew what bulb, etc. Works good now
Fly Z28 is offline
warmeck
02-05-2015 11:04 AM
cmdeshon
12-27-2014 10:06 AM
fpete1992
12-11-2014 03:51 PM
siguy
11-27-2014 10:07 AM
07-04-2005 05:00 PM
Quick Reply: question about dash lights
