pulling heads pass side
Old Jun 10, 2007 | 09:19 PM
smithtim's Avatar
so I'm pulling heads on a 3.8 fbird on the pass side and there are 2 pipes/hoses in the way I want to take out of the way ( just behind the altenator, look like AC hoses that go forward into what looks like a canister, ?? compessor ?? , and back into a black box which looks like it goes into the interior of the car).. they are held together by two nuts, think one is 15/16" & one 1"
anybody know what these are? and if I remove them what am I going to need to refill, freon??
Also, if it is Freon it safe for me to do this at home garage just by releasing the compresed air or is there a professional way that it needs to be done
thank you in advance
TIm
Old Jun 11, 2007 | 05:11 PM
Dave89IROC's Avatar
yeah, those are AC lines, legally, you need it evacuated by a certified and properly equipted individual, however, if it should leak out.............
you will need it vacuumed down and recharged afterwards
if it SHOULD leak out(from a loose fitting say..), be very carefull, you can get frostbite from it
Old Jun 11, 2007 | 05:14 PM
mdacton's Avatar
also...if you should find a LOOSE fitting and take it apart.....tape up the ends to keep out dirt and moisture.
also be sure to have a good vac. pulled on it....that get the moisture out of the system
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
Chris Anderson
Jan 27, 2015 08:30 AM
Amshnock
14
Jan 18, 2015 11:47 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
siguy
Nov 27, 2014 10:07 AM
