Problem with 95Z28
Old Sep 10, 2005 | 06:05 AM
xfreshjiv12x's Avatar
Problem with 95Z28
The first time I noticed the problem was yesterday. I would be at a light and take off at a normal pace in first gear (A4) it would rev up to about 2K rpm's and then it would hesistate or choke for just a split second, it eventually went away, but when I parked it was running rough and the ses light came on. Fast foward to this morning I was on the interstate doing about 70mph, when all the sudden the rpm's dropped down to ~1500rpm then jumped up to ~3000rpm , when that happend the ses light came on and then a loud bump or pop maybe backfire? looked back and there was a ton of smoke. Then my engine shut off so I coasted to an exit and looked at the engine, could not see anything tried to start it for a couple seconds it would not start. So I waited about 3-4 min. and tried it start it again and it cranked up just fine. drove it the rest of the way with no problems.... Anybody want to give a whack at it? The ses light is off now, any way to check the past ses with an akm cable and laptop?
Thanks in advance
Old Sep 10, 2005 | 08:24 AM
DSmith97Z's Avatar
Re: Problem with 95Z28
My 94Z had the same symptoms as yours is doing. Sounds like the opti-spark is on its way out. That fixed mine.
Old Sep 10, 2005 | 08:29 AM
Trouble codes will be stored until the PCM is reset. You can still check them.
Old Sep 10, 2005 | 09:43 AM
Great... . I'll check the trouble codes too thanks
Old Sep 10, 2005 | 11:30 PM
Ok shoebox I checked the codes that were stored and here are the ones that were in there: 16:lo-res failure;36:hi-res failure. So I am thinking it has something to do with the opti? but there where a few other weird codes that came up for my a/c which I just got fixed (ac clutch) the codes were: MALF 66:A/C Press Sensor Open/Short. MALF 67: A/C Press Sensor Degraded. MALF 69: A/C Clutch Circuit Open. MALF 70 A/C clutch relay fault (ODM). MALF 22: TPS Low. I used freescan and those are the trouble codes I got.
Old Sep 10, 2005 | 11:34 PM
I'd reset the PCM and see what comes back. It does sound like you might have opti problems. You might want to first check the harness on both ends for a good and clean connection.
Maybe some a/c stuff going on, too.
Old Sep 10, 2005 | 11:42 PM
Ok i am going to check the opti tomorrow thanks!
Old Sep 11, 2005 | 03:33 AM
Strahley's Avatar
Hope you get it worked out, opti sure does suck
http://www.lifeinwidescreen.com/siihp/opti.gif
Old Sep 16, 2005 | 04:54 PM
Update. I replace the ignition control module. It seemed to have fixed the problem but after driving it for about 1hr on my way to school with no problems I pull into a spot and sit with the engine running after about 10min the engine cut off no sputtering no bogging nothing just cut off. So I tried to crank it again cranked up and idled/ran fine. When I got home I started messing with it it after if ran for a bit it cut off just as it did at school It never stalled out when I had the RPM above idle say around 1000 ran fine. Then the SES light came on. I took it to a friend with autotap the Code was I believe the code was 33 or 34 saying something about the bar too high or low forgot! lol Anyways the autop measured ~4.5V on the BAR. no matter if I revved it about to 5K RPM the BAR was still 4.5V. So I took the connection off the MAP sensor Disconnected it completly and the damn thing was still measuring 4.5V! Is that the problem? That is the only trouble code coming up!! I have a htpp 3 installed could that be a problem in reading the codes correctly?
Old Sep 17, 2005 | 05:59 AM
Ttt
Old Sep 17, 2005 | 06:44 PM
Does anyone know if the HTPP 3 would affect the map sensor?
Old Sep 17, 2005 | 08:06 PM
I don't see how.
Old Sep 17, 2005 | 09:46 PM
Well it is werid when we pulled the connection off of the MAP sensor it was still reading ~4.5 volts, as if something else is controlling the sensor or bypassing it... I dunno
liamcg97
Nov 25, 2019 05:55 PM
Matt W
Apr 24, 2015 12:54 AM
AlaskaZ28
Apr 17, 2015 08:54 AM
greenzee28
Mar 26, 2015 09:13 AM
RichJ
Sep 26, 2002 09:43 AM
