Power Windows
Old Oct 1, 2004 | 03:12 PM
gamagus's Avatar
Power Windows
Need help with power windows on a 95 Z28 convertible. Driver window will go down when you first start car and then will not move again. If you turn car off and start again, it will go up but then not back down again. Heard it could be the acutator or the switch. Anyone else had this problem and how did you solve it??????? Can't take out on beautiful day if window will not go up and down.
Old Oct 1, 2004 | 04:46 PM
americanmusscle's Avatar
Re: Power Windows
Sounds like your window motor is shot.
Old Oct 2, 2004 | 11:58 AM
Re: Power Windows
If you need to replace the window motor (sounds like it), you might want to take a look at this procedure.
Old Oct 6, 2004 | 04:14 PM
gamagus's Avatar
Re: Power Windows
Shoebox,
Thanks for all of the info. It is a tremendous help and I think that is the problem for sure.
Thanks again.
Old Oct 6, 2004 | 04:34 PM
ChrisS95TA's Avatar
Re: Power Windows
I did this recently. Here is a tip, use some zip ties and make a loop ( or two linked loops if needed ) and run it through one of the holes on the motor. Now you have a handle to prevent it from falling down or too far out of place while trying to manuever it out or in. I used this method to get the old one out and new one in and I am sure it saved me some time and aggravation.
Good luck it is not that hard of a job !
OH yeah and I got my motor at Autozone for $40 and it has a lifetime warranty
Old Oct 8, 2004 | 11:49 AM
gamagus's Avatar
Re: Power Windows
Thank you for all of the helpful info. We can now fix our window maybe.
Keenan
Jan 19, 2023 12:24 PM
1996LT1Z28
Jul 20, 2015 02:00 PM
capebuf
Jan 13, 2015 07:22 PM
XtremeLt1
Sep 13, 2002 08:50 PM
MilkyClr69
Jul 29, 2002 10:01 AM
