Power window seems to be binding up
Old Dec 8, 2008 | 03:39 PM
wrd1972's Avatar
When raising the right side power window on my Camaro, it will stop in random places like something is binding. I have done the thermal breaker bypass and I have done the relay mod so power is not the problem.
I recently lubed the tracks and inspected things and everything looks good. Seems to come and go.
If you lift the window by hand while raising it, I can not feel any binding. Really pissing me off.
Could this be the motor going bad?
Old Dec 8, 2008 | 07:06 PM
Counted Out's Avatar
That's what happened when my motor went bad.
Old Dec 8, 2008 | 07:17 PM
dan_white798's Avatar
im having this same problem with my driver side window. i was planning on just replacing the motor. have you or anyone replaced one yet? if so could you tell me where to get some instructions and where to buy the motor? thanks
Old Dec 8, 2008 | 09:52 PM
http://shbox.com/page/windowmotor.html
Old Dec 8, 2008 | 09:59 PM
wrd1972's Avatar
This motor was been replaced by the dealer back in the warranty days. I have the access holes already drilled in order to remove it which is a piece of cake. Guess i will go ahead and get a new one.
Old Dec 8, 2008 | 11:31 PM
Green96Z's Avatar
Mine used to rattle like crazy and get stuck sometimes, turned out most of the teeth were rounded off on the regulator. If you change out the motor and it doesn't fix it you could always take it back (I did that once ).
Old Dec 9, 2008 | 07:36 AM
cool_breeze's Avatar
Mine did the same thing when the motor was going out, if you already have those holes drilled then it's pretty easy, I used a piece of 2x4 wood to brace the window up while I removed and replaced the motor.
Keenan
Jan 19, 2023 12:24 PM
1996LT1Z28
Jul 20, 2015 02:00 PM
capebuf
Jan 13, 2015 07:22 PM
XtremeLt1
Sep 13, 2002 08:50 PM
MilkyClr69
Jul 29, 2002 10:01 AM
