Power window problems...
Old Sep 6, 2005 | 07:07 PM
gt_biker13's Avatar
Question Power window problems...
My drivers side window makes a "clunk" sound when it goes down and also makes the door pannel bulge out when its all the way down. When the window is down it also rattles over bumps. The window works fine but these noises are annoying and something isnt working right. I allready took the pannel off once and found that the 4 screws were loose that hold the big wheel, i thought i fixed the problem but i guess that wasnt it
On a side note when i had the pannel off i found that theres lights in the doors that shine on the window switches, had to replace the bulbs but at least that works now
Old Sep 6, 2005 | 07:14 PM
blind527's Avatar
Re: Power window problems...
It may be off track. The power window motor is also very common to go out.
Old Sep 6, 2005 | 07:21 PM
gt_biker13's Avatar
It still goes up and down, so it could still work if its off track? How hard is it to put it on track? any guides for this problem?
Old Sep 6, 2005 | 07:23 PM
blind527's Avatar
It will still go up and down if it's off track, but it may not seal all the way. I heard getting these windows back on track is a huge PITA. Here is a writeup on the power window motor
Old Sep 6, 2005 | 09:04 PM
FNDRB58's Avatar
Off track really means you have a regulator issue (the jacknife tracks w/coil). If its not working properly, it will put stess on the window motor and reduce its life. If you buy all the parts you need, you can have a body shop spend an hour to install it with rivots, etc. (a body shop quoted me one hour) Not a bad deal.
When you take off the door panel and you raise and lower the window watch the rivots and see if they move. You did say it is bulging so that of course is another indication.
Old Sep 7, 2005 | 01:36 PM
DriverJ's Avatar
Major PITA job here. Its tough with two people. I've had power window problems with almost every vehicle I've ever owned.
I've swapped the motor and regulator on two different vehicles and would rather not have to deal with it again. Your best off having the shop do this one because of how the spring is packed
Keenan
Jan 19, 2023 12:24 PM
1996LT1Z28
Jul 20, 2015 02:00 PM
capebuf
Jan 13, 2015 07:22 PM
XtremeLt1
Sep 13, 2002 08:50 PM
MilkyClr69
Jul 29, 2002 10:01 AM
