power window motor
Old Aug 6, 2006 | 12:34 AM
lr383's Avatar
power window motor
Have any of you guys had trouble with autozone replacement motors for your windows? they give new ones but last for 4 or 5 months. Is there a better replacement that I can get? Or should I just buy a new factor motor. Thanks for your replys.
Old Aug 6, 2006 | 12:42 AM
Gun5's Avatar
Re: Dam power window motor
got mine off ebay... no name **** work good
Old Aug 6, 2006 | 12:46 AM
ttop1986's Avatar
Aw damn i got an autozone one sitting downstairs untill i have time to put it in. Hope it doesn't die quick on me. But its got the lifetime warrenty on it, so itll only be another pain in the *** to replace it.
Old Aug 6, 2006 | 12:52 AM
LenT1's Avatar
Ive had my autozone replacement for about 6 months now. Worked great when I first installed it but it isn't as fast anymore. Works decent still but not as fast as it was on day 1.
Old Aug 6, 2006 | 08:50 AM
LT1_383's Avatar
I spent the $90 on a GM one. The first one lasted 10 years, this one should too.
Old Aug 6, 2006 | 06:07 PM
pcgamer4life's Avatar
I'd be cheap and not spend any more money. As long as you have the lifetime warranty, who cares? Every half-year isn't bad, especially if you've changed it yourself in the past. I did my driver's side on my v6 and the passenger side on my z28, I feel comfortable I could do the swap in less than 15 minutes in the autozone parking lot.
Old Aug 6, 2006 | 06:14 PM
jonota's Avatar
Dont' forget that you need to clean and regrease the regulator arms... making the motor work harder than it's supposed to is a good factor for killing it quicker.
Jonota
Old Aug 7, 2006 | 10:57 AM
93redBirdMan's Avatar
Re: power window motor
I just installed a new passenger window motor in my TA and its slow as hell. DONT buy a remanfucatured one from Napa, thats all i have to say. We even cleaned and greased everything in that damn door and it still goes slow.
Old Aug 7, 2006 | 05:46 PM
jonota's Avatar
Pull the window switch and measure the voltage you get on the wire going to the power window while putting it up/down. The switches can build up a high resistance over life, especially if you up and down the windows a lot. This can be solved by pulling ALL the wires off and cleaning, then reinstalling... or sometimes just swapping the switch.
Jonota
Old Aug 7, 2006 | 08:43 PM
Dave '97 Z28 M6's Avatar
That's what I did.
capebuf
Jan 13, 2015 07:22 PM
Jazsun
Dec 29, 2014 12:14 PM
XtremeLt1
Sep 13, 2002 08:50 PM
MilkyClr69
Jul 29, 2002 10:01 AM
