Pipe for cat
Re: Pipe for cat
Originally Posted by RedHottG2
Why not just punch the honey comb crap out and save the $$ on an off road design ? It's pretty much the same thing.
Re: Pipe for cat
I have an aftermarket exhaust with a 3 inch I pipe. The factory Y-pipe is I think a sorta oval shaped 3 inch pipe. I just went to autozone and got a pipe with a 3 inch outside diameter flare on one end and a 3 inch inside diameter flare on the other end about 18 inches long. I first cut the cat off at the weld where the Y-pipe went together into one pipe. Slid the inside diameter 18 inch pipe over the Y(actually pounded it on), and of course put the outside diameter one into the 3 inch I pipe. Welded everything up and tada, makeshift off road pipe. Works perfect.
Re: Pipe for cat
Originally Posted by OutsiderIROC-Z
I am not sure of what it will sound like with a gutted out cat.
It's up to you man, I just always took the cheapest rout when it came to the cat.
