PCM not triggering EGR?
Old Mar 17, 2011 | 05:02 PM
dst's Avatar
dst
Smile PCM not triggering EGR?
Condition: EGR does not actuate.
I've replaced the EGR, tested the circtuit and EGR function and come to the conclusion that the PCM is not sending signal to the EGR to operate.
What could cause the PCM to NOT send the signal to actuate the EGR when the engine is fully warm and RPMs above 1500?
Manual says coolant temp sensor, MAF, and TPS influence EGR. I've tested power/ground/function/circuit to PCM for those sensors. All good but I do not know how to test calibration on the MAF or ECM.
1997 Camaro 3.8L 5 spd, runs fine, no codes, and 165k original miles.
Nayr
Mar 3, 2023 08:34 PM
93 RedBird
Nov 15, 2015 08:24 AM
fift5
11
Oct 1, 2015 10:31 AM
drt
Sep 27, 2015 04:39 PM
Pwilson59
Sep 3, 2015 08:47 PM
