parking lights..
Re: parking lights..
If the turn signals work but the park does not, the problem is either bulb, wires or headlight switch. If the marker lights don't work either, the problem is probably the switch. I know this sounds dumb but try new bulbs before you do anything else.
If the marker lights work, you will have to ohm the brown wire on each socket to the splice. The location of the splice is vague. Somewhere in the front of the radiator between the left and right lights is my guess.
autoxr166
Sep 25, 2015 04:21 PM
meissen
Aug 11, 2015 06:05 AM
