Pacesetter Install Iput
Old Jun 2, 2004 | 09:52 PM
robb4964's Avatar
Well Just to let you all know , The installation was not bad at all . I was sweating it because I couldnt find a good article on the install process for these headers . It was fairly simple .
remove Manifolds , starter , altenator and bolt thrue motor mount " Drivers side "...Raise engine up as needed to fit headers in " Drivers side only " . They will go in with ease . My headers mated up with no problem at all on either sides .
Old Jun 3, 2004 | 12:55 PM
Jay-Roll's Avatar
Glad to hear everything went well. What gasket/bolts did you use? Also what kind of exhaust setup are you going with?
Old Jun 3, 2004 | 05:15 PM
robb4964's Avatar
TSP catback sounds so badass with these headers and cam . Thats what I have now . I love it . I used the stock gaskets " they gave me new ones " And I used the new bolts " they gave me new bolts also "
Old Jun 3, 2004 | 11:05 PM
95_LT1_6SPD's Avatar
wow, i cant believe how these installs differ from car to car. Some guys take the starter off, some dont. Some guys have a real pain on the drivers side some on the passenger yada yada yada.
One question for ya, hows the clearance on yours to the streering shaft?
Old Jun 3, 2004 | 11:48 PM
robb4964's Avatar
There wasnt any..thats why you have to take the motor mount loose . Without taking the mount loose , I would never have got the headers in . Whoever the guys where that beat back the fire wall and ground the Shaft where not thinking when they did that stuff .It was cake once the motor was raised up a little . They went right in ..No problems . Taking the starter off is so easy . It takes less then 3 minutes and goes back in just as easy . WHoever does not take this stuff off is looking for the lazy way in ..Wich....actually takes more work and time in the end .
Old Jun 4, 2004 | 12:13 AM
Spinner's Avatar
Takes 2 minutes to remove the steering shaft. I dont see why it's an issue at all
Old Jun 5, 2004 | 08:16 PM
gav'spurplez's Avatar
glad to hear the install went well. looking forward to it since i will be getting my paces' soon
Old Jun 6, 2004 | 11:26 AM
wow, that got turned around
i was asking how the clearance with the steering shfat is after you go everything in.
Nov 18, 2023 07:21 PM
drptop70ss
May 4, 2015 08:22 PM
WildRidez
Mar 27, 2015 08:22 AM
alex5366
Feb 17, 2015 09:07 AM
