Overheating 70 Camaro 350ci
Old Jul 11, 2011 | 07:51 AM
stevev5320's Avatar
I have a 70 camaro that over heats at high speed. If I am at normal driving speed city roads it get up to 192-210 and holds. When I go at highway speeds 70-75 MPH it raises and gets to 230-240. any ideas??
I have just recently replaced the fan clutch and have not seen if that helps.
Old Jul 11, 2011 | 08:23 AM
redneckgames's Avatar
Re: Overheating 70 Camaro 350ci
What shape is the system in?
Have you made sure the fins are clean? (no leafs, dead bugs, etc?)
Have you flushed the system lately?
Are you certain the temp gauge is reading correctly?
What shape is the coolant in?
If you are running higher rpms then it makes sense that there will be more heat. If you are only getting a limited amount of airflow (like at normal driving speeds) it will heat up with the increased load on the motor.
Old Jul 11, 2011 | 08:30 AM
stevev5320's Avatar
The system was flushed and the radiator seems to be in good working order. There is good flow and the coolant is clean and fresh. Only other issue is I do not have the front spoiler on. Some have suggested it is needed for directing air to the engine area.
Old Jul 11, 2011 | 12:35 PM
n2ceptor's Avatar
Is there a fan shroud???
Old Jul 11, 2011 | 03:14 PM
rv93's Avatar
i know the front spoiler is absolutely crucial for cooling the 4th gens. not sure if its as important with yours, but it would be a good guess.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
CARiD
Jan 14, 2015 04:00 AM
ChrisFrez
Dec 21, 2014 09:47 PM
ChrisFrez
Dec 15, 2014 03:09 PM
