Outer Door Panel
Outer Door Panel
My wife and I bought a 94 Z28. The outer skins for the door panel is broken away from the rest of the door. A friend of mine told me that usually happens if someone tries to break in.
My question is how can I repair this? Since the doors are fiberglass is there an epoxy or cement that can be used?
It's a known problem. Don't think it has anything to do with break-ins.
And yes it's just glued to the inner panel. If you get the correct glue from GM or a body shop supply store, you should be able to glue it back together.
P.S. Here's an example: http://www.autobodysupply.net/URLrew...m&Redirected=Y
Aaront810
Aug 29, 2020 09:34 PM
z28cam1993
Sep 9, 2015 04:08 AM
