oil temp gauge
Old Feb 5, 2006 | 11:51 AM
Loopz28z28's Avatar
oil temp gauge
on a 02 z28 auto how would I install an oil temp gauge electric or mechanical auto meter ultra lite gauge?
Old Feb 5, 2006 | 08:39 PM
95nicotineZ
Guest
Posts: n/a
Re: oil temp gauge
I think those gauges use a sender that is inline with your oil pressure sending unit, you might have to ask Auto Meter about that one.
-Dave
Old Feb 5, 2006 | 09:10 PM
MAGIC Z's Avatar
Re: oil temp gauge
i have a mechanical auto meter and my stock gauge hooked up there is a differance from the 2 but i keep them both
Old Feb 5, 2006 | 10:59 PM
Re: oil temp gauge
Not sure what the oil drain plug looks like on an 02 Z28, but on my LT1, I use an electronic oil temperature gauge, with the sending unit drilled and tapped into the oil drain plug. There is a connector in the wire, so the wire can be disconnected to remove the plug to drain the oil.
A mechanical temp gauge is generally difficult to install, since the gauge is permanently attached to a long capillary tube with a bulb that needs to be threaded through the firewall. Easier to run a wire.
Old Feb 6, 2006 | 08:20 PM
Loopz28z28's Avatar
Re: oil temp gauge
thanks guys. I'm going to check with Auto Meter. I have a magnetic oil plug but I might be able to get a different one and drill it out and tap it.
Magenta_Hearts
Mar 29, 2017 08:54 PM
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
cmdeshon
Dec 27, 2014 10:06 AM
brentbrowning01
Dec 16, 2014 06:35 AM
ro2207
Dec 4, 2014 06:18 PM
