Oil and Spark Plug Change
Old Jul 2, 2004 | 02:20 PM
rokudan's Avatar
Okay first let me note that I worked as a mechanic years ago. Before Synthetics and before 93+ Camaros. Damn I am old..
Anyways, I am not sure if the previous owner used Synthetic or normal oil. I have heard that switching to Synth can cause oil leaks and such. Is there any way to tell what had been used? Or am I safe to use a quality standard oil, as long as I keep it changed regularly? If it is best to use a non-synth oil, what brand is advised?
Question 2: I would like to change the spark plugs at this time also. I've read about some people drilling a hole in the wheel well. I would rather not go this route. Are there any good tutorials, with pics perhaps, that detail changing the plugs. Additionally, what plugs would be recommended?
Back in my day K&N's were the thing to do as far as air filters go. I dont subscribe to the theory it would gain any hp, but do they not filter out contaminents better than conventional filters? Again, recommendations?
Any other PM items I missed please let me know. FYI it is a 2001 Z28 Automatic with 84k miles. The car seems to be well taken care of, but I want to establish a base to go from as far as PM'ing the vehicle.
Thanks..
Greg
Old Jul 2, 2004 | 02:25 PM
teke184's Avatar
remove the coil packs and the AIR tubes (push them asside) and you can access all the plugs with GREAT ease
Old Jul 2, 2004 | 03:54 PM
rokudan's Avatar
Good deal! I am reading around the Internet that the 2000+ models are a good bit easier to change the plugs in..
What plugs are recommended? I've heard NGK TR55. Don't Camaro's come stock with plats due to life cycle? Are plats okay? Iridium? I want to get a decent spark, but I dont want to have to change plugs every other month either..
Old Jul 2, 2004 | 05:36 PM
teke184's Avatar
expensive plugs are not worth it in my opinion.
4 of my 8 plugs had the small platnum "cap" thingy missing...makine the gap nearly .80"!!!!
and normal plugs will last 25k easy...so why spend $8 per plug when i can get ngk's for $2 each??
i can swap plugs in probably under an hour...
stick with NGK tr55s gapped to factory .60" specs
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
mritter1965
Feb 9, 2015 07:01 PM
Jazsun
Dec 29, 2014 12:14 PM
