Oil pan
Old Oct 18, 2011 | 03:58 PM
1eez28's Avatar
Oil pan
Hey guys I think I spun a bearing and so I was thinking of pulling the oil pan down and seeing if i did or not and I seen the cross member was in the way and I have no idea how to get around that so if anybody could help me out that would be great. It's a 1995 z28
Old Oct 18, 2011 | 04:17 PM
Hank'sZ28's Avatar
Re: Oil pan
1eez28,
Here's the oil pan removal procedure that I followed:
1) Disconnect the negative battery cable. Remove the air intake duct.
2) Raise the vehicle and support it safely with jackstands.
3) Drain the engine oil into a suitable container.
4) Detach the oil level sensor connector, then remove the sensor.
5) emove the catalytic converter.
6) Remove the exhaust pipe hanger bolt/screw and reposition the pipe.
7) If equipped with an automatic transmission, detach the cooler lines from the clip at the oil pan.
8) Remove the starter motor.
9) If equipped with an automatic transmission, unfasten the converter cover bolts/screws, then remove the cover.
10) Remove the engine mount through bolts/screws.
11) Use a suitable jacking fixture to raise the engine enough to provide sufficient clearance for oil pan removal.
12) If the front crankshaft throw prohibits removal of the pan, turn the crankshaft to position the throw horizontally.
13) Unfasten the oil pan bolts/screws, studs and nuts. If necessary, rotate the crankshaft to reposition the counterweights.
*diagram courtesy of gmpartsgiant.com; all rights reserved
Old Oct 18, 2011 | 04:32 PM
1eez28's Avatar
Re: Oil pan
sweet man that sounds a lot easier then people where tellin me to do
Old Oct 18, 2011 | 05:01 PM
1eez28's Avatar
Re: Oil pan
where did u put the jack to raise it???
Old Oct 20, 2011 | 04:26 PM
camz28ryan's Avatar
Re: Oil pan
Trust me it's not easy. We used a nylon strap, lifted engine
with a cherry picker.
HectorM52
Jul 30, 2017 11:46 AM
Noct
Jul 14, 2015 01:18 AM
jl1ne
Jul 7, 2015 08:38 PM
streetbad
Advanced Tech
Jul 5, 2015 10:40 PM
SergheiS
Jul 5, 2015 03:27 AM
