oil leak
Old Jun 1, 2006 | 10:43 AM
frusciante fan's Avatar
oil leak
every once in a while my car will leak a small bit of oil. it leaves a spot about the size of a nickel. i had my car on a lift a couple weeks ago and it was a bit greasy, by what i believe is called the main oil seal.
anyway it appears the leak is coming from right after the oil pan. the oil pan gasket was replaced last fall. it leaked only one other time and that was the day after i changed my oil, and then took a 150 mile trip.
everything else is fine. should i be worried about this?
'98 camaro V6
Old Jun 1, 2006 | 10:56 AM
GhostZ28's Avatar
Re: oil leak
nope. and sometimes its better to let it leak rather than to plug it. just park with a pad under the car or some oil sweep.
Magenta_Hearts
Mar 29, 2017 08:54 PM
surreybrad
Apr 22, 2015 06:40 AM
BigWil
Mar 29, 2015 12:24 PM
artic94
Jan 17, 2015 11:19 AM
