occasional no crank condition?
Old May 19, 2005 | 06:36 PM
ChicagoTransAm's Avatar
Once in awhile, my T/A won't kick over. I'm thinking maybe it's VATS. Seems like if I turn the ignition to off, and then back on...it'll kick right over, but never had a car do this before. Any clues?
Old May 19, 2005 | 06:52 PM
resurrectedz28's Avatar
Re: occasional no crank condition?
Ya, mine doest sumthin like that also, i posted on ls1tech.com, next time im in there doing changes im going to check out the starter and maybe do the relay that was suggested. Check out this link, might be helpful
http://ls1tech.com/forums/showthread.php?t=321304
Old May 19, 2005 | 11:09 PM
Joe Bellman's Avatar
Loose battery cables can cause intermittent starting problems and so can bad battery cables.
Old May 19, 2005 | 11:15 PM
See if the security light is staying on the next time it does not start. That will tell you if it is VATS related.
Old May 20, 2005 | 03:14 AM
Yes....the security light is on when I am trying to crank ....probably a bad key? Anyone have any luck replacing the "sensor" with a resistor? I have heard that that is all it is
QuickSilver02
Apr 7, 2015 11:12 AM
Dylan Latshaw
Mar 21, 2015 09:48 AM
Queens94z28
Dec 20, 2014 09:11 PM
