OBD1 SES Light Problem
Old Jun 27, 2004 | 01:18 AM
99BlackTA's Avatar
I have a 1994 pontiac trans am and my SES light keeps coming on for a while but then turns off. I have tried to test it and when I put the tested in the harness the electric fans turn on and the SES light flashes WAY too fast to read it. My electric fans keep on turning on driving around even when it isn't hot. What could be the problem?
Old Jun 27, 2004 | 02:52 AM
dabez1's Avatar
You cant flash the codes on a 94, You have to get it scanned. Go to local shops and ask around.
Old Jun 30, 2004 | 12:04 AM
99BlackTA's Avatar
When the SES light comes on the car kinda feels like it stumbles and I also noticed that today it made some loud pinging a couple of times. What different things could cause this other than the 02 sensor? I mean things that will trip the computer code too.
Old Jun 30, 2004 | 12:21 AM
Lt1t56's Avatar
Many things can trigger SES light, code scan is best thing to do. A guess if car is running properly would be EGR valve.... guess only.
Old Jun 30, 2004 | 12:26 AM
99BlackTA's Avatar
Unhappy
I have tried to get it scanned multiple times but every time i take it there the light is off when it is tested and soon as I leave it pops back on for a while.
Old Jun 30, 2004 | 12:34 AM
DonHood's Avatar
The PCM stores the trouble codes for quite a while. Even if the light isn't on, the scanner will still get the code.
Old Jun 30, 2004 | 01:08 AM
99BlackTA's Avatar
It kept saying no codes have been stored.
Old Jun 30, 2004 | 01:14 AM
Lt1t56's Avatar
Wish it would store a code for you. I will list my symptoms of my EGR failure for you... Car ran great all the time, light would come on only while highway-steady speed driving, then go off, but once light came on cooling fans stayed on until car was shut off.
Old Jun 30, 2004 | 01:18 AM
99BlackTA's Avatar
Well my car is definitely bogging down with more throttle and pinging a lot. I don't have a lot of money to spend on it right now. I hope that I don't have to replace everything that I think is wrong with it just to nail it.
Old Jun 30, 2004 | 04:27 PM
DonHood's Avatar
Does it run fine sometimes, then when you're applying steady pressure to the gas and trying to maintain speed, does it start to slowly bog down untill it corrects itself or you give it more gas? If so, it's probably O2 sensors.
Old Jun 30, 2004 | 08:21 PM
99BlackTA's Avatar
Yes those are the exact symptoms and it pings sometimes too.
Old Jun 30, 2004 | 08:40 PM
DonHood's Avatar
Just make sure you replace them with AC Delco O2 sensors. People seem to have problems with Bosches and other brands. Also best to do both at the same time, because the if you only have one out right now, the other one will probably follow soon. You can get the O2's from www.gmpartsdirect.com for a decent price. I believe the part # is 25312184.
P.S. The passenger side is a pain to replace, but the drivers side can be done in no time.
Old Jun 30, 2004 | 08:42 PM
DonHood's Avatar
I'd also like to add that an Electron Blue C3 Corvette is the stuff wet dreams are made of.
Old Jun 30, 2004 | 10:39 PM
99BlackTA's Avatar
Thanks so much. I went ahead and bought some Bosch ones from my work(Autozone) a couple of days ago but haven't had the chance to install them. I ended up selling the vette a couple of months ago to another guy on this board that lived close by me. I put A LOT of hard work, money and TIME into that car. It is a very quick beauty.
Gtpguy
Jan 26, 2015 04:50 PM
97z28k&N
Jan 9, 2015 04:58 AM
sleeperZ96BT
Jun 5, 2005 09:33 PM
Rich_z28
Sep 13, 2002 03:35 PM
Z28Wilson
Aug 1, 2002 04:27 PM
