98 Z Door Hinge adjustment
Old 09-04-2014, 11:02 PM
Suprabuilder's Avatar
On my 98 Z the drivers door is sagging. I want the door to stop rubbing the body and smacking the fiberglass against the striker bar. I understand i probably need to loosen the bolts that hold the hinges to the body. I have also searched and seen to loosen bottom hinge more than top and just raise corner of door up. My questions are.....
Whats the best way to get to the bolts? Through the wheel well or......
Also whats best to use a ratchet and socket or flat wrench?
Thanks so much
Suprabuilder is offline
Old 09-05-2014, 07:42 AM
Prominent Member
GaryDoug's Avatar
Location: Born on the Florida West Coast, now where can I retire?
Re: 98 Z Door Hinge adjustment
Before you try adjusting it, check to see if the door is cracked. Mine was and that resulted in the same symptoms you have. If it is, the crack can be repaired with fiberglass and epoxy.
I found the best wrench to use was a 12-point offset 13mm (1/2") closed end wrench. The only one in my toolbox that worked was an old one from Montgomery Wards ;-) I was able to loosen them through the hinge opening.
98 Z Door Hinge adjustment-13mm-wrench.jpg98 Z Door Hinge adjustment-98ta-door-repair.jpg
GaryDoug is offline
Old 09-07-2014, 04:45 PM
Wow thank you so much for the detailed response. I'll check for any cracks then I'll search the box for an offset wrench to loosen bolts without removing things.
2QUIK6
09-17-2016 02:31 PM
tomfric
Parts Wanted
07-30-2015 03:01 PM
realistyc
07-28-2015 07:32 PM
Chevyguy358
Parts Wanted
07-20-2015 07:42 PM
CARiD
07-07-2015 08:19 AM
Quick Reply: 98 Z Door Hinge adjustment
