Not gettin gas to my motor..??
Old 06-18-2005, 11:15 PM
1crazylt1's Avatar
Angry Not gettin gas to my motor..??
ok..well wen i go to turn my car on it will just crank but wont start..it sounds like the motor is not gettin gas..but thats my opinon..does anyone think i need a fuel pump?let me kno..thanks
-1994 chevy z28 camaro-
1crazylt1 is offline
Old 06-18-2005, 11:30 PM
Bow94z's Avatar
Re: Not gettin gas to my motor..??
yea most likly fuel pump, its cranks but just nothing right??? how many miles are on the car? Check your coil too before you go and do a fuel pump change
Bow94z is offline
Old 06-19-2005, 03:01 AM
Kris93/95Z28's Avatar
Do the basics before attempting to fix the fuel pump. First, do you hear the pump kick on when the the key is turned to on position? Assuming that checks out, how old is the fuel filter?
Kris93/95Z28 is offline
Old 06-19-2005, 10:02 AM
Kataklysm's Avatar
Definitly make sure it either isn't getting fuel or spark before you go buying parts.
Kataklysm is offline
Old 06-19-2005, 01:27 PM
1crazylt1's Avatar
ok like 2 weeks ago brang it to the shop for boggin out..they changed the plugs,wires,fuel filter and disturbutor..the car has 110,00 miles on it. yes i do hear the fuel pump turn on wen u turn the key
Old 06-19-2005, 04:52 PM
OBE1 95Z28's Avatar
Attach a fuel pressure gauge to the Schrader valve on the fuel rails and check your fuel pressure. Fuel pressure should come up to around 36 psi and slowly decline after the pump stops (2 second time out). If the pressure drops quickly, the check valve in the fuel pump is shot and the fuel pump will need to be replaced.
OBE1 95Z28 is offline
94Maroz28
10-27-2015 04:38 PM
WobblySausage
10-07-2015 10:09 AM
68camaroboltz
10-05-2015 01:46 PM
95z_28_camaro_4_Ivan
10-03-2015 07:27 PM
drt
09-27-2015 04:39 PM
Quick Reply: Not gettin gas to my motor..??
