Noise in Rt. Rear Area?
Old Nov 9, 2004 | 02:42 PM
Red97LT1's Avatar
Unhappy Noise in Rt. Rear Area?
I have a clunk/bang intermittent noise whenever I drive my car for a long period of time. I changed the differential fluid a month ago and the gears inside there looked fine,there wasn't really any pieces on the magnet inside the diff. case. I tooke the tire off and didn't see anything that may be the cause of the noise. I don't notice any other problems except for when I drive for long periods of time.Any ideas???Thanks
Old Nov 9, 2004 | 02:58 PM
Kataklysm's Avatar
Re: Noise in Rt. Rear Area?
Shocks, lower control arms, torque arm. Check all of them for looseness.
Old Nov 10, 2004 | 10:40 AM
HBHRacing's Avatar
Did you add the limited slip additive?
Old Nov 10, 2004 | 11:26 AM
wblocker's Avatar
im betting on shocks, im having the same issue right now.
Old Nov 10, 2004 | 11:43 AM
Red97LT1's Avatar
Don't have limited slip.I used the regular gear oil.
Old Nov 10, 2004 | 11:44 AM
Red97LT1's Avatar
It's annoying,but only when I drive for awhile is when it does it??
Old Nov 10, 2004 | 12:00 PM
HBHRacing's Avatar
What diff did you put in your car then?
Old Nov 10, 2004 | 12:06 PM
2001NBMZ28's Avatar
Did you replace the stock diff? If not look for RPO code G80 - Axle Positraction, Limited Slip.
Old Nov 10, 2004 | 12:09 PM
HBHRacing's Avatar
Unless he replaced it which I doubt he's got to have a LSD. In which case you NEED the additive it the geas will bind up and make a horrible clunking sound from the right rear area. I went through this on a customers V6 fbody. After seeing he had the Y87 package and that 2 weeks ago someone did axle seals for him I made a bet that there was no additive in it. I was right, have not seen the car since we added it.
Make SURE that you don't have a LSD
Old Nov 10, 2004 | 07:17 PM
Red97LT1's Avatar
It is the factory differential that I have and I used 80w-90 gear lube. Do i have limited slip? How do I tell???
Old Nov 10, 2004 | 08:06 PM
Hyperspeed97z28's Avatar
you better go get the gm additive from the dealer and add it ....
Old Nov 10, 2004 | 08:12 PM
Red97LT1's Avatar
Should i change the fluid again since it's not synthetic or just add the additive? I was told that 80-w90 was the weight????
Old Nov 10, 2004 | 08:52 PM
HBHRacing's Avatar
that weight is fine but YOU NEED THE ADDITIVE. you have a factory limited slip diff that MUST have the additive. Go to the dealer NOW and get the 4 ounce bottle and put it in.
Old Nov 10, 2004 | 09:29 PM
Red97LT1's Avatar
Ok. Going to get the additive tomorrow. I am going to go ahead and put some 80-w90 synthetic in it while i'm under there. I hope that this will fix that annoying noise.
Old Nov 14, 2004 | 04:43 PM
Red97LT1's Avatar
I meant to post a couple days ago. I changed the lube added the additive,now it's quiet.Thanks for the info guys.
Fatdog2
Feb 12, 2015 12:24 PM
camy 1993
Feb 3, 2015 06:26 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
Dec 4, 2014 11:56 AM
squarehead
Nov 21, 2014 08:02 PM
