No heat!
Old Sep 25, 2011 | 12:53 PM
Grizz's Avatar
No heat!
stopped blowing heat and air. is there a fuse, or did my compressor go out or my fan motor?
Old Sep 25, 2011 | 03:25 PM
Re: No heat!
There's a fan in the box for the HVAC that pulls air through the system to pick up hot or cold, depending on where the temperature rotary dial is located. If you had air flow, and the air flow completely stopped, it may be the fan motor (there is no compressor involved with the heat - that's for the A/C).
Alternatively, if there is air flow, but it doesn't respond to turning the temperature rotary dial, it may be a problem with the cable from the **** to the flapper door in the HVAC box.
If the is air flow, but you can't control which vents it comes out of, its a problem with the vacuum supply to the HVAC controls. That is usually due to a problem with the check valve in the vacuum line from the intake manifold.
Here's Shoebox's diagram:
http://shbox.com/1/hvac_vacuum.jpg
That all assumes you had heat, and it stopped suddenly. If it stopped gradually, the heater core may be plugged up and needs to be flushed out with a garden hose.
Old Oct 1, 2011 | 01:08 PM
Grizz's Avatar
Re: No heat!
the heat will blow out if im running down the road, out of all vents but not if im at a stand still
Old Oct 1, 2011 | 03:24 PM
Re: No heat!
The motor is accessible by dropping the insulation panel on the bottom of the passenger side of the dash. You should be able to tell if the motor is running or not when the fan switch is moved to the various fan speed positions.
Nayr
Mar 3, 2023 08:34 PM
93 RedBird
Nov 15, 2015 08:24 AM
CARiD
Sep 30, 2015 05:44 AM
Daluchman1974
Sep 11, 2015 06:12 AM
damnyankee36
Sep 9, 2015 07:06 PM
