Need QUICK help, overheating!
Old Apr 17, 2004 | 12:46 AM
Stang Spanker's Avatar
So my car is overheating, BAD. The needle can't go anymore to the right. I dont have experience in these things, because usually by taking care of my car I avoid this stuff. I checked the oil, and it was ok ... I checked the coolant, and it was ok. I could hear bubbling from under the radiator cap. I dont know what else it could be, but I have to get to work in the morning so I need some help quick.
Thanks everyone!
Old Apr 17, 2004 | 08:23 AM
redzsmoked212's Avatar
is there any leaking coming from anywhere?
if the radiator is bubling it sounds like your thermostat is bad and not circulating the coolant through the engine.
when you put coolant in make sure you put it in the radiator and the resevoir or you will create an air pocket and get more of that bubbly sound and it wont flow through.
oh yeah make sure you go 50/50 collant water
Old Apr 17, 2004 | 10:24 AM
Jaswir's Avatar
yea sounds like ur thermostat wont open up so it can go threw the engine
Old Apr 17, 2004 | 10:29 AM
jm8881's Avatar
I hate to say it, but if the needle can't go anymore to the right then your engine is runny veeeeeery hot. And alluminum heads don't like that too much. Hopfully it didin't cause any damage.
Old Apr 17, 2004 | 12:32 PM
You guys are on the ball, it was indeed the thermostat. $130, guess it could have been worse. Thanks guys.
Old Apr 17, 2004 | 12:58 PM
ibanez6rg's Avatar
I hope you didn't pay $130 for a stat!
Old Apr 17, 2004 | 02:19 PM
Rashiki's Avatar
I just picked up a new 180 degree stant stat for 9 bucks
68camaroboltz
Oct 5, 2015 11:56 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
NewsBot
Sep 14, 2015 09:20 AM
damnyankee36
Sep 9, 2015 07:06 PM
Pwilson59
Sep 3, 2015 08:47 PM
