Need help to remove the AC clutch on our 94 Camero
I can't figure out how to remove the ac clutch. The bearing is definitly going. All I see is a threaded rod in the clutch center. Also if I can get it off should I replace the whole clutch assembly or just the bearing? If just the bearing is it easy to get out? If no one can help will someone direct me to an online source that can?
Thanks!
Thanks!
Biggiebound
Apr 20, 2015 07:16 AM
