Need Help, Possible Cooling Problem???
Old Mar 30, 2006 | 12:38 AM
b_lesy's Avatar
Exclamation Need Help, Possible Cooling Problem???
ok, i have a '95 z28, and when i drive around town (just cruising at slow speeds) the temperature gauge seems to go unusually high. i thought maybe it was a fan not kicking in or somthing, so i put the code reader on and nothing seems to be malfuntioning. the guage never reaches the "danger zone", but it does get up there. i was just wondering if anyone else has had this problem and if so, what the problem might be.
thanks
Old Mar 30, 2006 | 12:40 AM
StephenDeli22's Avatar
Re: Need Help, Possible Cooling Problem???
Could be a dirty/clogged radiator, or maybe a sticking thermostat
Old Mar 30, 2006 | 06:16 PM
b_lesy's Avatar
rad was just flushed about 3 months ago and a new thermostat was just put in.... so i doubt its either of those
Old Mar 30, 2006 | 06:24 PM
b_lesy's Avatar
thanks for the input tho
Old Mar 30, 2006 | 07:34 PM
6SpdLT1Z's Avatar
how hot? Keep in mind that our cars run prettty hot. Average temp driving is 190-195* and upto 235* at stop lights
Did you bleed the air after replacing the thermostat?
Old Mar 30, 2006 | 07:35 PM
6SpdLT1Z's Avatar
Here's a pic for reference.
Image Copyright of Shoebox.
Old Mar 30, 2006 | 07:40 PM
infinitebird's Avatar
That's normal behaviour if you have the stock tune.
No fans turn on until 226. High fan comes on at 235 so it will get that hot if you let the car sit for a while.
Get a tune so the fans come on earlier or a manual fan switch.
BigWil
Mar 29, 2015 12:24 PM
Lt4Z2897
Mar 26, 2015 03:02 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
MattFick
Feb 15, 2015 10:16 PM
